Rim Choices For 01 Zo6/drag Radials
Old 02-29-2008, 03:14 PM
turboolds's Avatar
Default Rim Choices For 01 Zo6/drag Radials
Whats My Best Bet For Drag Radials On A 01 Zo6, I Need Rims Too, I Was Thinking Of Getting 2 Replica Rims And Use Them And Buy A Drag Radial, Any Suggestions, Also Does The 17in Front Rim Fit On Back?
Old 02-29-2008, 03:19 PM
Photochop's Avatar
Yes the fronts fit the rear. I've seen some guys over on corvette forum running a 17x11 zr1 style wheel and the MT or similar DRs on them with success.
Old 02-29-2008, 05:06 PM
carado1984's Avatar
well for stock size wheels you can use the 305/35 nittos or MTs for better grip and in 315/35 the bfgs..
And personally i would do the 315/35 MTs because they hook better than nittos and then you only have to buy 2 wheels and can buy whatever on the car now unless youre going to use them just for the track..
A lot do use 17x11s and MTs are your best bet for a 315/35 unless you want to use an M&H 325/40 which should hook a little better given the extra almost 2 inches in sidewall... But both will fit, both should hook.
Edit- You might want to double check this with the member 'Ranger' but i believe hes running 17x11s on his c6z06 with radials not sure what size or kind but hes running high tens and i know he previously owned two c5z06s that ran mid to high elevens on radials. See what he thinks...
