Rear Weld Prostar With Spacer on 95z
Hi Guys i just got some 15x8 weld prostars for the rear, they have 5.5 backspacing my question is can i just run a 5/16 spacer in the rear like how you can on the fronts or will there be some sort of problem i will be also using the stock studs aswell. I dont care about passing tech at he track cause it is primaray use is on the street.Oh and one more thing i heard you cant use the center caps in the rear wheels is that true, my car is a 95z. thanks
