What gauge setup are you first gens using?
Old 03-01-2008, 04:42 PM
Shawn MacAnanny's Avatar
Default What gauge setup are you first gens using?
I removed my factory 160mph speedo and other gauge today and just realized what an extreme angle this dash is on. I self tapped a piece of sheetmetal up there that i cut to fit around the colum and all to try to get an idea of how to make it work but i'm just at a loss. I would pretty much have to construct a box to lay within the dash to hold my gauges at a visible angle. Are there any kits out there already made? I alread have my gauges, Auto meter, tach, shift light, oil pressure, water temp, there will be 2 A/F gauges and a matching speedometer as well at 4-5 toggle switches.
Old 03-01-2008, 07:33 PM
Midnight68's Avatar
Well 5" autometer gauges fit right in the original housing.
Or you can buy a Covans unit.
http://www.covansclassic.com/
Old 03-01-2008, 10:29 PM
Yeah after i posted this and i did some searching. Summit sells one from Covan classics that is made of plastic, undrilled for $120
http://cgi.ebay.com/ebaymotors/CCL-1...spagenameZWD1V
That what i'm going to go with. Thanks man!
