View Poll Results: Which BMR Fabrication suspension product do you want to win?
Billet Control Arms (BMR# ACA002)
25
13.44%
Lowering Springs - Front and Rear (BMR# SP001)
15
8.06%
Sway Bar Kit - Front and Rear
56
30.11%
Adjustable Torque Arm (BMR# TA001)
90
48.39%
Voters: 186. You may not vote on this poll
FREE Suspension Part from BMR Fabrication
LS1Tech Premium Sponsor
BMR Fabrication will be giving away a FREE suspension part on April 1st!!
This is NOT an April Fools joke. BMR is really giving away a FREE suspension part on April 1st. Which BMR suspension product are we giving away? That’s up to you.
Vote for the BMR product that you want (between now and March 8th). Then sign up for the April 1st Give Away by inserting the BMR banner into your signature. That’s it!! We’ll send you a PM if you are the winner.
We’ll also put pics and/or videos of your car on the front page of our website. You can show all your friends. How’s that for bragging rights?
Here are descriptions of the BMR product that you can vote on :
•Billet Control Arms (BMR# ACA002) : These BMR lower control arms are CNC machined from billet 6061 T6 aluminum alloy and black anodized. It's almost a shame to bolt them under a car where you can't see them! Carved from a 2" x 2.5" solid billet, nobody will have to worry about breaking these. We have also upgraded the bushings and inner sleeves with thicker material to handle whatever you can dish out. Made in the USA! ($229.95 value)
•Lowering Springs (BMR# SP001) : BMR progressive rate springs lower the car 1" yet retain the OE ride quality. The front springs have a progressive spring rate that increases from 310 pounds/inch to 550 pounds/inch as the spring is compressed. The rear springs have a progressive spring rate that increases from 140 pounds/inch to 175 pounds/inch as the spring is compressed. ($229.95 value)
•Sway Bar Kit (BMR# SBK001 – 4th Gen) or (BMR# SBK002 – 3rd Gen) : These BMR sway bars are 32mm front(solid) and 21mm rear(solid) to replace the factory 30mm(hollow) and 19mm sizes and add stability to the F-Body platform. Made from cold formed steel to better resist torsional fatigue and retain their "memory" far longer than conventional hot formed bars. This front bar is over 40% more rigid than the popular 1LE swaybar. All packages come with new Prothane mounting bushings and endlink kits. ($349.95 value)
•Adjustable Torque Arm (BMR# TA001) : Made from MIG welded 1.25" x .120" tubing with heavy duty 1/4" mounting plates. Bolts directly in place of factory torque arm using all factory mounting locations. Requires no welding or drilling and clears all factory or aftermarket exhausts. It comes equipped with a rear adjuster for adjusting pinion angle. It also comes with a new, low deflection polyurethane front mounting bushing. ($329.95 value)
There will be 2 threads for this poll – 1 here and 1 in the Sponsor Sales forum. We will add the results of the 2 polls together to pick the winning product.
You may enter the contest now or you can wait and see which product wins. If you want to enter now, just put a BMR Fabrication banner in your signature. The banner is shown below. The banner must link to the BMR Fabrication website and you must keep this banner in your sig in order to be eligible to win.
Please post back here after you add the banner to your signature and you will be eligible to win!!!
Here’s how to put the banner in your signature:
1. Right click on the BMR Fabrication banner below and select "Save Picture As.."
2. Save the picture to your hard drive
3. Go to User CP and open Edit Signature
4. Go to Option 2, and left click the Browse button
5. Find the image file on your hard drive and click the Open button
6. The filename and path should be in the Option 2 box
7. Click the Preview Signature button
8. The banner should now be shown under Your Current Signature Picture
9. Put the cursor in the white box under Your Signature
10. Click Insert Signature Picture
11. You should see in the white box
12. Put the cursor in the white box in front of the and type [ URL = http://www.bmrfabrication.com] without any spaces
13. Put the cursor in the white box behind the and type [ /URL] without any spaces.
14. When you're done, it should look like this [ URL=http://www.bmrfabrication.com][SIGPIC][ /SIGPIC] [ /URL], except no spaces.
15. Click Save Signature.
woot im #2 in here maybe im the 2nd winner
btw: i'd be happy if i won anything, so if I win, it wouldnt matter to me, but i say either lowering springs, or the sway bar kit, it would be perfect!
Its hard to choose I need all of those suspension mods on my car but I went with the most expensive, Torque arm.........hope i win at least a shirt, im dirt poor and have been wearing the same van halen shirt for a few months
