How much boost with S-D concepts spring tentioner
Old 03-09-2008, 08:45 PM
Restricted User
Lawnboy's Avatar
Default How much boost with S-D concepts spring tentioner
How much boost can S-D concepts 8 rib spring tentioner support?
does it realy help with belt slip? How does it hold up , and failers-Problems using it? How does the belt hold up with it ?
I am running a ATI LS1 super damper and 8 rib solid tentioner procharger set up now, but i am interested in the SD concept spring tentioner for later when i want to make more boost.
Old 03-09-2008, 08:50 PM
NemesisC5's Avatar
Where can I get info on this product?
Old 03-09-2008, 09:02 PM
TT-TECH Veteran
Inspector12's Avatar
Here you go Scotty although I don't think it will stay up long.
http://www.sd-concepts.com/
Old 03-09-2008, 09:09 PM
NemesisC5's Avatar
Thanks Jeff...looks to be only for F-Bodies?
Old 03-09-2008, 09:17 PM
Restricted User
Lawnboy's Avatar
yes F-bodies, only , i hear a lot of guys are using it
Old 03-09-2008, 09:36 PM
Tom@SpeedInc's Avatar
It does help with belt slip
we've used SD tensioner with F1A and 18psi, with the ATI bracket we couldn't get past 15psi.
