Rear end busted hole in tunnel!!
Old 03-10-2008, 04:11 PM
IGNANt's Avatar
Exclamation Rear end busted hole in tunnel!!
Has this ever happend to anyone? I noticed it when I removed the carpeting... a 1" hole at the end of the driveshaft tunnel. What caused the hole? Its the top bolt that connects my Spohn TA to the Moser 9"... Im on stock shocks and springs and still have the bump stops...
Has this ever happened to anyone?
Do you think its caused by launching hard at the track or maybe in the streets somewhere when I had a couple people in back seats?
Ill try to get some pics up tomorrow...
Old 03-10-2008, 04:16 PM
bigsticksupra's Avatar
LS1Tech 10 Year
it's the torque arm bracket and the upper bolt on the rear end housing.
NufNuffZ28's Avatar
I have seen several aftermarket torque arms that seem to do that. Especially on 12 bolt and 9" rear ends. Sometimes if you play with it and do a little hammering yourself you will avoid the torque arm "clearancing" itself. On other cars we have seen NO way to avoid it hitting the tunnel no matter how we set it up...
Old 03-10-2008, 11:52 PM
CW00BlackTA's Avatar
I have a 9 inch and mine did it--just not as bad.
Old 03-11-2008, 03:56 AM
wabmorgan's Avatar
We have got to SEE that!!!!!11
Old 03-11-2008, 04:45 AM
LS1Tech 10 Year
here is mine..
COOL! not.
now that it self clearanced itself, i am going to get it welded back up.
Old 03-11-2008, 07:29 AM
billyb's Avatar
Default bolt dents
hi i think the reason is you are suppose to drop the bolts in from the top not put in from the bottom from the top only the head would be sticking up ?? my .02
Old 03-11-2008, 12:36 PM
JScamaro's Avatar
This is the only thing from stopping me from buying a 9" rear. My car will be lowered and I don't know if I'll have enough clearance in the tunnel area with my torque arm.
Old 03-11-2008, 05:44 PM
lgobraves's Avatar
mine does the same thing...i need to get up there and try to grind on the rear
