Will boost leak out the direct port nozzles on my fast 90?
Ok..I know some of you guys don't like the fast 90 and recommend the ls6. Well I already have the fast 90 and don't plan on selling it. I have seen the fast go like 20psi already in several boosted applications. I won't likely be much over 15psi max. I was planning on direct port zex nitrous system.I have zex wet kit non direct port but was likely going to put that on my 96z28.
Have any of you boosted guys ,turbo or supercharger run the fast 90 and zex direct port and did you have any problems losing boost thru the nozzles. Don't seem to be that great a setup since the intake is not metal. So just wondering if can expect leaking at the nozzles and if there is anything that a guy could do to stop it if its a problem.
I am planning on small shots of spray likely stick around 100 shot or so. If its like my dsm cars the nitrous shot seems to be magnified a bit by the turbos and puts out even more power than rating would suggest.
