Throttle by Wire TB bolt to Throttle cable TB?
I am pretty sure the answer to this is yes, but I want to ask it before I spend money on it.
Do the Throttle by wire throttle bodies use the same bolt pattern as the conventional throttle cable throttle bodies? Ie: can I bolt a Throttle by Wire onto a older engine, or bolt a cable TB where a wired one was?
Appreciate the info.
