What is the GM PN for this hose??
soo. awasome first..2 days of having the car back on the road. busted trq. arm mount last night. fixed that to day. and now i have a very large leak in the hose outlined in red below. its awasome...ill bet the opti is next on my cars list of things to go
would any one happen to know what the PN for thise hose is? or where abouts it goes??? its not very easy to see in the dark
That would be your heater core lines. PN # 10236039 for your 94. I suggest if you havent already do the coolant bypass mod. I cant really tell by that pic if you have. Also you could do what i did and buy the 95-97 heater core lines that dont have that stupid nipple for the smaller coolant line that leads under the air elbow to the upper radiator hose. If you do that you will also need the 95-97 upper radiator hose. The part number for the 95-97 conversion is #10261147. I dont know the number for the 95-97 upper radiator hose but rockauto has them as well as gmpartsdirect.com just look at there catalogs.
