How many times can you resurface stock flywheel?
Need a quick answer. I already cut mine once. Can I go once more??? Or should I just get a billet steel unit??? I would rather not spend the money if I don't have to.
I have already done it twice on my original flywheel. Once when I simply replaced my clutch with a stock unit and then again when I upgraded to the ls7 clutch and gave my stocker to my buddy. Both times worked absolutely fine with no issues. You should be fine...I would think a dial caliper would be your best bet though if you are real worried. Simply locate the factory accepted specs for the thickness and measure it to be sure your ok. Keep in mind that my flywheel had over 110k the second time around.
