i need help asap..
Old 03-15-2008, 01:31 PM
DSRCAM's Avatar
Default i need help asap..
ok i installed my heads and cam yesterday and well as i went through the plugs today i could tell that only one side is firing.. i check the passeneger side and the spark plugs are all black and the driving side. its almost as is its not firing at all. i chek the grounds behind the head and it bolted down good.. does anyone have any ideas..
Old 03-15-2008, 01:41 PM
Z28Fistergod's Avatar
Does it start, run at all? Double check connection for the coil-pack harness.
Old 03-15-2008, 01:51 PM
DSRCAM's Avatar
yeah it starts and everything i also chek the coil connections but its just doesnt wanna fire the driver side..
Old 03-15-2008, 02:24 PM
Did you get all the grounds on the head, there should be 3 on the drivers side. Try disconnecting the coils and probe the connector to make sure your getting juice, and also check for zero ohms between the negative pin in the connector and ground on the battery -. Check for zero ohms between the head and the battery -, make sure you are getting a good connection with the probe on the head, if in doubt place both probes on the head, it should be zero or close to it ~0.1 or 0.2.
Old 03-15-2008, 02:34 PM
DSRCAM's Avatar
cool man im gonna chek it out.. i know it has to be a ground somewhere thats im not getting proper connections..
Old 03-15-2008, 02:40 PM
This might help...
Old 03-15-2008, 03:12 PM
DSRCAM's Avatar
thnks man i gotta figure this out..
