Injector question
Injector question
Ok guys I swapped out my stock truck injectors out of an 05 6.0L for a set of 42lb delphi injectors for use with the supercharger. My question is about the wiring since the connectors are different. The stock truck wires are pink and black and the new connectors that I have are pink and blue. Am I correct to assume that the pink wires need to be soldered together and the blue to the stock black? I have the schematic for the truck and pink is power for the truck but want to verify that is the same for the camaro injector harness. Thanks in advance.
