No Spark!
Old 03-19-2008, 09:52 AM
THEBRAD's Avatar
Default No Spark!
my friend has a 99 ss camaro, there is no spark coming from the plugs. it just stopped running one day and we looked it up and it was said that either the engine management control fuse was blown, it wasnt but we changed it anyways, or the crankshaft position sensor, changed that also and retuned it with hp tuners. car will still not start no spark still what so ever. any help would be flippin excellent
Old 03-19-2008, 10:10 AM
01WS6/tamu's Avatar
Need to hook up a scanner and see if it shows rpm during crank. If not the ckp may have fragged. Check all of the fuses. That is almost always a dead give away to the ckp croaking. no spark, dead ckp. or wiring connection. If you have headers check to make sure they are not melted together.
Old 03-21-2008, 10:03 AM
THEBRAD's Avatar
might take it to the dealership today let them worry about it lol
Old 03-22-2008, 12:30 PM
89tang's Avatar
Fixed the car. You guys put the relay for the ignition in the wrong spot. The fuse boxes had the wrong lids on them. So you replaced the fan relay. Put the new relay in the ign. spot and fired right up.
Old 03-22-2008, 07:27 PM
THEBRAD's Avatar
hahahaha when we were looking at my t/a duane was like i need this fuse and i was like the fan? cause they were switched thats funny
