Vacuum Issue
Vacuum Issue
https://ls1tech.com/forums/forced-induction/858217-won-t-idle.html
Just keeps getting worse and worse. LOL Low vacuum (under 10inHg). Read away, I really need some help with this one. Thanks in advance!
I have a vacuum line running from a bung on the charge pipe right before the throttle blade all the way to the pro-gate (bottom port). I have a vacuum line run from the booster/boost gauge T attached to the megasonic BOV for reference behind the throttle blade. I am stressing out, because I don't have time to work on this thing, and it's been an ongoing problem that no one seems to want help solve. What is wrong?
