Water Pump Difference
What exactly is the difference between the truck WP and Fbody pump besides the upper radiator hose inlet location?
I'm tying to see if I can make an use an Fbody pump with truck accessories and vise versa.
You also may have to modify an Fbody tensioner to fit as well. I used the truck tensioner and removed about 1/2" from the standoffs.
Eventually, I went back to the truck pump since later mods to the engine didnt require the clearance around the water outlet.
