Camaro too low for me?
Hey guys, i'm about 5'6 and i'm pretty short in my upper body.
I know that camaros sit pretty low and i'm not sure if i can see over the dash...
Can anyone move the seat to the highest point and measure from the seat to the top of the dash? It'd be a great help to me.
I know mustangs sit higher, and a mustang GT is an option, but honestly i'd rather sit on books in a camaro than drive a mustang
Also if it's any difference i'll be getting a 98+ camaro.
Thanks guys!
Thanks guys!
It would be a close call but my friend who is 5'0 can barely see over the dash to the front of the hood so i'd imagine with you being 5'6 you should have no problem seeing over the dash to the front of the hood.
i know what u mean by not being able to see over the whole front end. Im 6'1" and i can see over but not as much as other cars. took a bit to get used to. Youll get over it
OWN3D BY MY PROF!
You'll have a false idea that it's you that's the problem with visibility. In reality you can't see much out of these cars period. My Camaros are better than my Formula visibility wise, but I doubt anyone on here can see the front of the car unless they are seven feet tall.
The seat rises and moves forward ALOT!! I would assume an asian midget could drive it.
I have to move the adjustments all the way back and all the way down to drive it and i'm only 5'11"
even if i were 7 feet i still wouldnt be able to see where the front of the car ends.. esp. for the 93-97 models. well if i had a giraffe neck that measured 2 feet long with the t tops off then... yea
I let my sister learn how to drive stick in my car, she's 5 3.
I'm 5 10 and have no issues with visibility. The only thing you need to keep in mind is that the nose of the car is LONG compared to other cars. So turns in which you think the front may clip, probably will clip. It really messes me up when driving the Monte SS or my Accord as I think I can't clear when maneuvering when in reality because of driving f-bodies all my life there's plenty of space. Also steep driveways require coming at them from an angle for the same reason. Other than that, most cars you can't really see the front anyways, so what makes you think you should be able to in an f-body?
