Difference Between Corvette and Camaro blocks
Old 07-24-2003, 03:30 PM
crguy7's Avatar
Default Difference Between Corvette and Camaro blocks
I heard that the corvette has a 4 bolt main block and the camaro has a 2 bolt main block. I just wanted to clear this issue up. Thanks.
Old 07-24-2003, 03:41 PM
Samba242's Avatar
Default Re: Difference Between Corvette and Camaro blocks
No difference in the mains..... and I believe both are splayed 6 bolt mains aren't they?
Old 07-24-2003, 03:46 PM
BurnOut's Avatar
That was the case with the LT1, but the LS1 has 6 bolt, cross-bolted mains regardless of the application.
Four bolts are straight in (two on either side of the crank), and two of the bolts go in from the side of the (deep skirt) block.
Old 07-24-2003, 03:48 PM
crguy7's Avatar
Ok thanks for clearing that up for me.
