What size tires for these rims
http://cgi.ebay.com/ebaymotors/18-17...spagenameZWDVW
what size tires would i need for these wheels???
Thanks
Thanks
From the sticky: https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
Z06 Corvette Replicas:
17"x9.5" +50 to +56 mm no problems. 275/40R17.
18"x9.5" +50 to +56 mm 275/35R18 or 285/35R18.
18"x10.5" +50 to +53 mm. Higher than 53 mm will require the BFH mod. 285/35R18s thru 315/30R18. Over 295 may require rolling the fenderlip and will need the BFH. +58 mm is the typical available offset for the Z06 replica, which will require a little BFH and/or a small spacer.
-Mike
-Mike
