anybody done a cam swap?
Most vender cams you install dot to dot. You do not have to shim the springs at all.
I would search in the internal section. Take a look at ls1howto.com Thats what I used.
For a cam swp like AB said many cams already are set so all you need is to align the dots and your good to go. Im not sure about the LS6 springs, but when i installed my MS3 i used PRC dual valvesprings from TSP and they went in with no problem.
-Joel
-Joel
