Moser 9" axle seal part# ?
Does anyone have the part number for the axle seal on a Moser 9"? I've got a leak from the passenger side and need to fix it.
Thanks,
Scott
Thanks,
Scott
LS1Tech Sponsor
CR 15141 is the correct size but Moser some times uses a thicker press ring and it might run into the seal. To fix this you can grind down on the seal lip where the seal stops in the housing.
