New Slave Cylinder Question
Old 03-27-2008, 10:50 AM
PewterScreaminMach's Avatar
Default New Slave Cylinder Question
OK, this is related to a previous post, but I think this is a much better and simpler way to answer my question. Is there a part number difference between the 98-00 slave cylinder and the updated 01-02 slave cylinder?
I have the slave in question sitting in my room with the stamped part number on it, so I just need to compare if they are in fact different numbers. If not, then hmmmmm.....
EDIT: After some searching, it appears the "GM Part Numbers" that people talk about do not match up to the number stamped on my slave cylinder. It is definitely an LS1 Fbody slave cylinder, but the number stamped on it begins with the letter "D" followed by a bunch of numbers (have to go home to check).
I need to know if the stamped number on it is the one that changes or not.
