K member install question
Before I get flamed, yes I did do a search and didnt find the info I was looking for on here. I am installing the UMI K member on 2002 TA with the engine out. The brake lines that were attached to stock K member had 5 mounting points total, 2 on each side and 1 in the middle. I only see one hole in each side on the UMI K member. How did others mount this? Pics would be awesome. I am ready to put my engine on but I want to make sure this is done right first.
get your self some 1/4 strip steel and drill a hole in it big enough to fit the middle k member bolt on each side cut it about 5-6 inches long and cut your stock bracket apart saving the piece with the square hole that. this is the mounting tab where the hard line meets the rubber line. weld and paint. here is pic.
http://www.clanocdelta.com/z28/suspe...t/bracket1.JPG
you can also get there from my sig just dig around till you see suspension.
here is the driver side
http://www.clanocdelta.com/z28/suspe...idebracket.JPG
this literally took about 10 minutes to make if you do not have access to a welder make sure you mark both pieces before taking them some where. much cleaner than zip ties and less pulsation.
