The tach on my car doesn't read right.
Old 03-28-2008, 08:32 PM
Hotrod406's Avatar
Default The tach on my car doesn't read right.
I just got my 6.0 71 Vette running and the tach doesn't work right. I had the stock mechanical tach converted to electronic internals from a 75 last year and it worked fine with the MSD box on my SBC. With the 6.0, it works a little but is very lazy and doesn't ever read above 2000 rpm, even when I'm sure it's at 5000 plus.
I have it hooked up correctly.
I tried the resistor pull up wire and that did not make a difference. I tried 4700 ohm and 470, neither worked.
Someone has to have seen this before.
Any ideas?
Old 03-28-2008, 08:59 PM
Skele4door's Avatar
You know the LS1 has a 4 cylinder tach output right? That's probably your problem since your tach was setup for an SBC which has a traditional 8 cylinder output.
Old 03-28-2008, 09:15 PM
bad2dbone's Avatar
try gettin a computer or pcm swap r even a programmer might fix it
Old 03-28-2008, 09:17 PM
Hotrod406's Avatar
I started to think that way after reading a few threads. My tach is probably just reading at half speed. I'll have to have wait4me fix that. My tune will probably need a couple touchups anyway.
Old 03-28-2008, 09:42 PM
pnhigg's Avatar
I think you are on the right track
Quick Reply: The tach on my car doesn't read right.
