Cam Question
Old 03-30-2008, 01:09 PM
Z28Fanatic's Avatar
Default Cam Question
I've been thinking of swapping in a little bigger cam, but I'm not sure if it would really be worth it. Doing the actual swap wouldnt be bad cuz im about to tear into the car anyway... But what would I gain if I swapped in a 232/234-.595/.598-112 Comp XE-R cam? Right now I have the TR224 which spec'd out at 224/224-.556/.556-112+4. Thanks for any ideas.
Old 03-30-2008, 01:24 PM
rsodeputy61's Avatar
that's the same specs as the tsp torquer v.2. u may want to try a search in the dyno area and see some numbers... good luck
