ls6 cam help
Old 04-02-2008, 12:31 PM
droptopT/A's Avatar
Default ls6 cam help
ok i khow the ls6 cam is a small cam but my car is a dd and i didnt want a lopey cam i wanted something quiet.and also i am getting the ls6 cam brand new for 50 bucks from a friend my car is a 99 transam do i need new springs and if i do wich ones do i get
Old 04-02-2008, 12:42 PM
slowmofo's Avatar
yellow or orange ls6 springs.. stock springs will not work. You can run stock pushrods from what I have read and been told, but you could get some new chrome molys for around 100 bucks
Old 04-02-2008, 01:09 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Def get better push rods and at least 918 springs, just incase you decide to want more.
As for the cam a z06 cam is great for FI, if the car is to stay NA I would recommend something like a TR 224/224 or bigger. even with the 224 there isnt much lope to it. Also Thunder Racing does sell the Cheater cam which is DEAD stock sounding.
Old 04-02-2008, 03:04 PM
droptopT/A's Avatar
how much will i gain with this cam i have full bolt ons lts and bbk intake manifold and a vig 36 -3800 stall
Old 04-02-2008, 09:22 PM
kingsey's Avatar
If you already have the stall I would def without a doubt go with something a little bigger maybe a 224 or 228 cam. No need to go crazy.
Save your lunch money for 2 weeks and you can buy a cam package with a nice cam. LS6 isnt the best of cams
Old 04-02-2008, 11:12 PM
droptopT/A's Avatar
im not working right now so imkinda broke and i get bored at my house so i got this cam cheap already for 50 bucks i can learn how to put a cam and then later im goin to to heads and cam later later lol
Old 04-02-2008, 11:20 PM
MikeLSS1's Avatar
What kinda gains can you expect from an ls6 cam? Also is the thunder racing cam called the cheater cam? What could i expect from that?
Old 04-02-2008, 11:29 PM
NemeSS's Avatar
5-10rwhp tops if installing in a 241 head ls1 with an ls6 intake,
perhaps 20rwhp if a great tune is calibrated also for an ls6 cam.
may want to check thunder racings site, for cheatr specs,
all the info u need
Old 04-02-2008, 11:34 PM
conde'strans's Avatar
Personally, I think goin through all that work that installing a cam requires is gonna be worthless for an LS6 cam! That cam will give u no noticeable gain. My cousin installed it in his TA cuz he was being cheap and now wishes he woulda gotten a bigger cam cuz he sure had a hard time installing it himself!
Old 04-02-2008, 11:37 PM
MikeLSS1's Avatar
okay cool. thanks for the info ya'll
Old 04-02-2008, 11:38 PM
MikeLSS1's Avatar
oh i also had a couple questions in a thread i made right below this one entitled sleeper cams. ne1 feels like it take a look. sorry not tryin to thread jack or nething
Old 04-04-2008, 02:08 PM
droptopT/A's Avatar
ok i will be installing this cam myself do i need ametric wheel tool or just line up the dots
Old 04-04-2008, 02:43 PM
Internet Mechanic
Dot to Dot.
00pooterSS's Avatar
The LS6 cam is what I want to do also, I want to do it because I want to keep the best fuel efficiency while making an improvement in power. I would say 10-15 on the LS6 cam. MAKE SURE the last four numbers on the cam are 5308 not 1095 ( i believe its 1095 ). The 1095 is the 01 cam. You want the 02+ cam, also you can use LS6 valve springs, they are generally yellow, 02 and up are yellow, the 01 LS6 valve springs are green, they are the same as the yellow springs, I looked up specs on those two springs and they are the same.
You only need to line up the dots on the sprokets.
Let us know what you think about the LS6 cam when you get it in. Or at least me anyway
the cheater cam by Thunder Racing is also a great cam to use, I called thunder and that is what they suggested for MPG and a BROAD powerband, not a 6k+ rpm cam here is the specs on the cheater
Thunder Racing Custom Camshaft
"CheaTR" - 214/230 .601/.575 117 LSA. Off Idle-6800 RPM Power Band. Broad power range. Works well with stock exhaust manifolds and catalytic converters. Stock like idle. Minor tuning required on automatic transmission cars. Responds very well to nitrous. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Double valve springs and titanium retainers required for this cam.
but with that high stall etc, it will be underkill for your setup
Old 04-04-2008, 02:57 PM
droptopT/A's Avatar
cool thanks guys great help and ill let u khow what i think about the cam when i intstall it
Old 04-04-2008, 03:25 PM
slowmofo's Avatar
There are orange springs as well, I have a set of yellows and orange
Old 04-04-2008, 05:54 PM
DrkPhx's Avatar
The LS6 cam is a good cam. The key is to rev it at least 6600 rpms. Years ago I bought a used 02 LS6 cam/springs for $150. Bone stock the car dyno'd 290 rwhp. It dyno'd 348 rwhp with an unlocked Yank 3200 converter and the following mods: LS6 cam/LS6 intake, MAC headers, bolt ons and the converter. The biggest gains were up top where the LS1 cam falls down. At 6600 rpms the LS6 setup was nearly flat to 342 rwhp. Look at a stock LS1 setup (even with bolt ons) and you can clearly see the big gain up top. The car ran 12.4 at 109 mph all day long in hot weather and drove exactly like stock with no tuning (even though it helps).
Old 04-04-2008, 06:32 PM
LSJM1's Avatar
I picked 1 up for 50 bucks too and plan on running it in my LQ9 with a 76 turbo
Old 04-05-2008, 04:27 PM
droptopT/A's Avatar
do i have to change the push rods
Old 04-05-2008, 04:29 PM
Paint_It_Black's Avatar
you do not have to, no, the length will remain the same.
Quick Reply: ls6 cam help
