i need opinions on LT's v. stock manifolds
Old 04-03-2008, 01:00 AM
F-BodyGuy98's Avatar
Default i need opinions on LT's v. stock manifolds
hey guys...im running the STS kit on my 98 Z and when i dyno'd it it was dropping boost at 6200 rpm..we found the problem to be stock vavle springs and a new 6.0L is planned for the next project with a bigger turbo under the *** end...but how good would LT's work? i know for havin a stock engine manifolds are the way to go but i was going to wrap each header pipe and the exhaust all the way back when the new engine goes in...how well do u think that would work?...thanx for any input.
Old 04-03-2008, 01:05 AM
52172's Avatar
I am not an expert when it comes to the sts kits, but I do know the answer and that is stick with your manifolds! I don't think anyone recommends swapping the manifolds for lt headers until your CI get above 408. You could run a set of short tube headers and I do have a set I could sell you. Some JBA stainless, but that would only be for looks.
Old 04-03-2008, 01:08 AM
thats what ive been hearing from alot of ppl but it seemed like it could work...thanx for the input man.
Old 04-03-2008, 01:13 AM
52172's Avatar
no problem bro good luck with the build! Oh btw my brother and dad work out in your neck of the woods at AV hospital so I am out there every now and then. There is a lot of nice open road out there to open her up huh?
Old 04-03-2008, 01:20 AM
oh no ****! thats tight...yeah we have our fair share of open stretch of roads but then again those roads have a high population of CHP roaming around too...you can get away with it most of the time but u have to be careful as the were u chose to run
Old 04-03-2008, 01:31 AM
52172's Avatar
Oh forgot to mention Rob did my build and had Ken from HP tuners do the 2 bar SD tune. Have you heard about Rob getting his own dyno in the next couple months?
Old 04-03-2008, 01:59 PM
last time i talked to him he said he was still working on it but he doesnt have a for sure date yet
