Tuner Needed - Crank Recailbration Code 1336
After assembling my LS1 with a new timing wheel, crank sensor, and PCM, I'm getting code 1336 (Crank Relearn). Apparently, this is normal if you've changed any of the above components. Does anyone have a scanner who would be willing to come to Valley Stream, Long Island, NY 11581 to run the test and calibration on my car? The car will not be drivable for a couple of months and I would really like to solve this problem.
BTW - an OTC scanner does not have the capability to perform this recalibration. It needs to be one of the more expensive scanners like a Tech II or an LS1 tuning program.
Please respond with you price.
Thanks.
John
Thanks.
John
