Converter question
Old 04-06-2008, 10:24 AM
justatoy's Avatar
Default Converter question
I just installed a fuddle 3600 converter and ordered a tune from Ion. Now my problem is when I put it in drive the car is always trying to take off. How do I check to see if the converter is stalled correctly? This one feels as if it is stalled lower than my stock converter. Any help would be great. Thanks
Old 04-09-2008, 01:48 AM
LS1Tech Sponsor
performabuilt's Avatar
Well there are alot of ways a trans brake being the best test . but a quick simple test thats semi adequate would be to unhook the wiring harness from your trans placing it in limp mode then giving a quick flash of the throttle in D and what ever the tach jumps to right as the car moves is pretty close to accurate. However you will set a bunch of trans code that will need to be cleared afterward
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
