P0420 Code ?
Old 04-07-2008, 10:33 AM
RobZ's Avatar
Default P0420 Code ?
I have this code poping up,I did A search and many said it seems to be a defective cat.My Question is,I had new High Flow spun cats installed less than 2k miles ago and pretty sure its not the cats.Could the o2 sensor be bad?Thoughts?
Old 04-07-2008, 10:39 AM
98redorangeta's Avatar
just turn the code off you dont need it. Even if you dont have softwear getting the code deleted will be cheper than o2 sensor.
Old 04-07-2008, 03:21 PM
edcmat-l1's Avatar
Its because those cats arent nearly as efficient as the OEs. Turn the codes off. They wont stop popping up.
