TR6 or TR7 plugs?
Old 04-09-2008, 08:13 AM
lt170chevelle's Avatar
Default TR6 or TR7 plugs?
which plug should i run on my app...TR6 or 7 plugs?
And why? Does a colder plug make less of a spark?Would i have to run a a smaller gap with the colder plug?I have always ran them on my nitrous motors but not sure about boosted motor.
Old 04-09-2008, 09:02 AM
ZL1Killa's Avatar
sorry if i'm ignorant, but whats app?
your app , is that what you are simply stating?
what boost are you running?
I'm running TR6 plugs, they are 1 stage colder
Old 04-09-2008, 11:07 AM
azceta's Avatar
All depends on the amount of boost, total amount of timing, air charge temp, running alcohol or methanol injection. Start with the TR6 and run them then check them.
Old 04-09-2008, 11:45 AM
ok yeah i have everything in my sig..my app was reffering to my application..and i am running 8lbs right off the wastegate spring.this is my daily driver and will be on pump gas with low teens for timing
