Showing po 342 cam sensor low output. could this cause the the tach not to work? or does tach work off of crank sensor? car hard to start but run fine once started.
Forgot to hook up wiring harness on passenger side of motor. Who would have thought there would have been a connector between the crank position sensor and the PCM.
