oil pan leak
oil pan leak
alright so i just got done installing the shift kit. now i have a problem. after i bolted everything back up, i started pouring in the trans fluid. after every quart i checked to make sure there were no leaks. after pouring 3 quarts in, it became clear that there was fluid leaking through the gasket near the shift connector bolts. luckily i did not pour in all 5 quarts yet. so i started over in an attempt to discover a problem. no problem. so i reinstalled everything and attempted the procedure again. same dam thing. what can i do to solve this problem? if your wonddering the shift kit was from B&M and i know some will criticize but im past that, just want to know what the hell i can do to fix this. I wanna drive her!!!
yea i replaced the gasket completely. torqued it correctly. the gasket from b&m is like a cork material but im thnking...if i put some adhesive between the pan and the gasket, could that help some leaking? prevent any from leaking between small cracks? thanks for the help
