rods and pistons
Old 04-17-2008, 02:50 PM
spiritshotgun235's Avatar
Default rods and pistons
So, I'm thinking that my newest setup is gonna be a NA build. I'm lookin to get in the 11s on the motor, at full weight. What kind of rods and pistons would you guys suggest, assuming that money IS a factor haha. Don't ask me how much cuz I don't kno I just would like some suggestions. Thanks guys
Old 04-17-2008, 02:56 PM
1CAMWNDR's Avatar
You can do that easily with a stock bottom end.
Heads, Cam, Intake, Headers, Suspension, and a decent slick will do it.
Old 04-17-2008, 03:17 PM
Oh, I know the stock bottom will hold up, but I might wanna lay a two stage on it later on so what would you suggest as far as being safe
Old 04-17-2008, 03:18 PM
I'm thinkin a 200 shot btw
Old 04-17-2008, 03:28 PM
BIG_MIKE2005's Avatar
Well if your gonna build it now for a big shot later, your not gonna do it cheap & it be right. If I were planning that I would go:
Compstar rods w/ARP 2000 bolts
Diamond pistons (you decide -cc for your desired compression)
And honestly if your gonna rebuild the block, you should go ahead & do your heads, cam & lifters while your in there. If you don't you'll kick yourself in the *** later.
