cruise control
Old 04-17-2008, 09:48 PM
chad rock's Avatar
Default cruise control wont work when i got a th350
cruise doesnt work after 60e to th350 swap.please help
Old 04-18-2008, 04:37 AM
Tommy 35 SS's Avatar
idk what is electronically controlled on your car or not, but i do think on LS1 f-bodies with an automatic the cruise control is electronic. someone correct me if i'm wrong, i know my 02 camaro is
Is that what you're talking about because you didn't say what car u did this on and i guessed it was that WS6 in the picture?
i don't have a clue how to fix it, someone else help him please
Old 04-18-2008, 04:39 AM
or at least i think my cruise control is electronic? lol
Old 04-18-2008, 06:19 AM
87silverbullet's Avatar
Yes it is electronic. One of the inputs that the cruise needs to see is the speed from the VSS. Did you do the conversion of the speed sensor in the process?
Old 04-18-2008, 07:47 AM
chad rock's Avatar
no i did not do the speedometer but if i get it workin my cruise will work again ?its a 99 trans am.
Old 04-18-2008, 02:51 PM
It should work but I would need a wiring schematic for the cruise control to see what all the inputs are to make it work. I am trying to remember if the speed that VSS puts out has to be the same as the speed sensors on the wheels for the ABS to let the cruise work.
Old 04-18-2008, 04:10 PM
pddye's Avatar
If you get the speedo to work the cruise will work again. I did the abs trick to get my speedo to work again and it also got the cruise to work. Just jump the two wires off an abs sensor or get the vss to work with a different setup off the trans.
