want to forge my stock block?
maybe ill get better luck here
ok guys, i want to replace my rods and pistons in my ls1 346ci for some boost
i will be runnin a d1sc setup with about 11psi.
im wanting about 650hp. so which pistons and rods should i get and also any other things like piston rigs, rod bolts, and anything else yall would suggest ifor some boost.
thanks
thanks
http://www.exoticperformanceplus.com....html?item=683
http://www.exoticperformanceplus.com....html?item=686
We use the above combination along with Total Seal rings in most of our builds, such as this 346/D-1SC/740 rwhp build. http://www.exoticperformanceplus.com...Car.php?car=40 Bob
Turbo Addict
