the little thins. need help (APS)
Old 04-22-2008, 05:56 PM
Big Bird WS6's Avatar
Default the little thins. need help (APS)
well the little things like.
what kind of NGK spark plugs?
should i use the cometic exhuast manifold gasket?
02 sensors. anything different with a boosted car?
thanks
Old 04-22-2008, 07:12 PM
MY99TAWS6's Avatar
I am going to be running ngk iridium 6ix or 7 ix see how it goes. Don't like constantly changing spark plugs. Lots of guys run tr6 or tr7 think they said from .025 to .035 gap depending on boost levels. The tr6 and tr7 are copper and need to be changed out quite frequently.
O2 sensors just stock ones are fine unless you plan to run leaded fuel then you might need some lead resistant 02s.
are you talking cometic head gaskets? I don't think you need any special ex man gaskets as aps use stock type exhaust manifolds.
I am not sure if going to run cometic head gaskets or ls7 head gaskets. Forget if the ls7 are ok with my afr 225 72cc heads??
