will these fit under the wheel wells 305/45-18
Old 04-23-2008, 12:57 AM
SPEEDYTRANSAM1996's Avatar
Default will these fit under the wheel wells 305/45-18
i have a 10.5 rim but i wonder if these will fit under the wheel wells or are they to thick???????
thanks
Old 04-23-2008, 06:57 AM
DWZ28's Avatar
Old 04-23-2008, 07:26 AM
KyleLs1's Avatar
thanks
it will be iffy.. stock tire size is 25.7" tall approx.
These tires are 28.8" tall, if you are not lowered they may fit on the rear but you will probably have rubbing issues on both sides of the tire.
Proper size would be 305/30/18 or 305/35/18
Old 04-23-2008, 07:28 AM
KyleLs1's Avatar
Originally Posted by DWZ28
I ******* hate that smiley - if you take that much effort to tell somebody to use a search, you may as well answer their question....ffs
btw the search function is useless most of the time on this site
Old 04-23-2008, 11:59 AM
xBROKEx's Avatar
no they dont fit.
Old 04-23-2008, 12:05 PM
z28bryan's Avatar
That's a pretty serious increase in tire height and overall size. I don't know if they will fit, but if they do then it will be one hell of a squeeze. Considering tire height changes you would want to change your LCA length.
Quick Reply: will these fit under the wheel wells 305/45-18
