Can a WB 02 be used as a narrow band?
Title says it all. I'm running OL MAF now. I'm thinking about throwing 02's back in my car for a number of reasons. I have a WB and guage in the car now. The WB 02 is in the bung that the NB was using. Is there a way to use the WB to simulate the narrow band and leave the guage in place or do I need to add another bung, move the WB and run it seperately?
Thanks
Thanks
Assuming your WB has analog out you want to program the analog out and feed it into the stock PCM.
I don't think naming exact values will help you. If you know your car is tuned you want to make the values to where your car corrects with about 0 trims.
Program the WB to output
about 450 mv at 14.7
0 mv for about 15.3
990 mv for about 13.5
fudge the numbers [cause of headers, placement, ect] around to where the average trims your car develops match up with what the WB says.
Personally, I don't even have O2 sensors. They cost more than a WB sensor does. So I just tune it OL and I have a WB in the car I can watch when I want to.
0 mv for about 15.3
