Need a P/N
The bolt pattern for the gm mounts for the 60 and 80 are exactly the same. If it will line up in your cross member then you are good to go. Most after market mounts are exactly the same as for the bolt pattern. So I do not see it as being a big deal. Your welcome for nothing. Vince
