converter problem?
converter problem?
i think i either have a wrong concerter or there is something wrong with mine, i race a lot of 1/8 mile and havent been able to get to the 1/4 but i am starting to think i am not going to be able to. in the 1/8 mile i am in 3rd gear at 5800 rpm (6500 red line) i am traping 103 when i do one of those calculators to figure out how fast it should go pre gear. i should still be in 2nd gear. this happen both on motor and on nitrous, i am a little bit lower in the rpm on motor but still in 3rd gear. i am woulding if this could be the converter sliping too much?
any of you guys with a 3 speeds get into 3rd gear in the 1/8?
set up:
stock LS1
224/224 cam
th350 rmvb
9" 3.73
28" slick
175 hit.
3200 stall
edit: wrong rpm
set up:
stock LS1
224/224 cam
th350 rmvb
9" 3.73
28" slick
175 hit.
3200 stall
edit: wrong rpm
