quick drill mod question
Old 04-29-2008, 04:47 PM
Omec's Avatar
Default quick drill mod question
just drilled the line w/ the 1/8 bit. i went in about an inch w/ it. is the bit supose to be able to push in farther than the inch i drilled it. meaning did i drill enough? the bit stops at the point i stopped drilling. im guessing the inside dia of the hose isnt 1/8?
Old 04-30-2008, 07:26 AM
Cap'n Pete's Avatar
Keep drilling! It's a little more than an inch. It should go until the bit can go in completely with no stop (ie: until the drill bottoms out). The restriction was a lot deeper than I was expecting it to be. But so far, my clutch seems to be working great! (I just drilled the clutch line ~2 or 3 weeks ago).
Old 04-30-2008, 11:56 AM
Omec's Avatar
awesome man thanks!
Old 04-30-2008, 04:11 PM
DesertFox's Avatar
Yeah, I got it done two weeks ago. just make sure all the threaded part of the bit gets into the hole (thats what she said haha). and your good.
Well worth the effort.
Josh
Old 04-30-2008, 10:18 PM
ae13291's Avatar
the key to this mod is wraping the hydralic line with high heat tape! you would be amazed at how long the clutch fluid can stay clear! lol
Old 04-30-2008, 10:20 PM
Omec's Avatar
oh snap! almost forgot about that thanks dude. i drilled the rest of it. seems about right now.
Old 04-30-2008, 10:27 PM
ae13291's Avatar
good dude, keep up the good work, you might run into some trouble with the master cylinder u bolt going back into position! try working on that from the top!
