Rear Lower Control Arms
Old 04-29-2008, 05:45 PM
SSCamaro2000's Avatar
Default Rear Lower Control Arms
I was just wondering what everyone would recomend as far as LCA go for the back. Would boxed or tubular be better, is one brand better than the other? Would the relocation brakets help? Any input would be greatly appreciated, Thanks for you time.
Old 04-29-2008, 06:26 PM
95GreenZ28's Avatar
I run bmr tubular lcas and relocation brackets
Old 04-29-2008, 06:35 PM
'02 WS6's Avatar
It all depends on your setup and what you will do with it. Street racing, road racing, drag, etc will all utilize different styles. Then you have to look at rod ended, adjustable, poly bushings, poly/rod ended, etc. A search or even contacting BMR w/ your plans on here would probably be your best bet.
Quick Reply: Rear Lower Control Arms
