Who is running ls7 mls head gasket on their afr 225 72cc heads?
Need to pick some head gaskets right away.Its either cometic or the ls7 mls ones. Part number which I assume is correct is 12582179.Anyone running these on their afr and how are they working out? Still worried if go cometic will have to do more block or head prep. Should I copper spray the ls7 gaskets ??
Location: sneaking in your back door as you leave!/cartersville ga
ive got 6.0 iron block and 225cc afrs. i have not run it yet, but the coolant passages all looked the same. some one else chime in if they are different
i havent heard of the cooling passages not lining up. if that was the case the heads would be different also and wouldnt be able to interchange.
https://ls1tech.com/forums/showthrea...skets+head+ls7
look at post 20. those passages look identical to the passages that are in my 7.0l head gasket. (i have an extra one that i compressed wrapped in plastic)
if you look real close to the odd shaped water holes on the end of the gasket you will notice a slightly different shape. but they will be fine.
