FREE ECM Flash from Painless Performance
Looking to do an LS or Gen III truck engine swap? You know you'll need an engine harness. So do you buy an aftermarket engine management harness or get a wrecking yard OEM harness and start stripping out what you don't need? Well, you can guess what our recommendation is here at Painless. To help you along with that decision.........
Now, when you buy a Painless Performance EFI harness we will flash the factory ECM for FREE to eliminate the error codes that occur when transplanting these engines. We'll also make gear ratio, tire size and engine RPM changes. Plus a few others at no charge.
Only cost is $15.00 to handle return shipping and handling. For complete details go to our web site www.painlessperformance.com and click on ECM Re-Program under the PRODUCTS heading on the left hand column of the home page.
Any questions...... Call our tech line at 800 423 9696 Tell them you saw the thread on LS1 Tech. Won't get you a free toaster oven or anything but it will help us know where the calls originate.
Free flash
Let us know how you think the web site interface works for the details on your vehicle and engine. Feel free to share any suggestions after you go through the process.
Good Luck!
Gary
Good Luck!
Gary
