FS: Pentium II Desktop PC
My uncle used to be in the computer business and he built this for us a LONG time ago. Dad's been using it up until this year. Works like it should, but it comes up with "DISK BOOT ERROR, ENTER SYSTEM DISK" every now and then. Another restart and it works fine. I can't figure out why it does this. Other than that everything is perfect. Windows ME is the only OS on this.
I also have a beige keyboard and a black dell CRT monitor. I think it's 15".
I used some software to tell me everything about the PC. Here's the printout it gave me.
------PC Summary------
Computer System
Computer Name: VALENCIA
Computer User: Valencia Jewelers
OEM Info:
Hardware Info
CPU: @ @ @
Mainboard: (HOT-661)Intel i440BX
Memory: 223MB (45% Free)
Video: Trident Blade 3D PCI/AGP NO_ICD 4MB
Multimedia: SB AudioPCI Record v4.4
Network: AOL Dial-Up Adapter
Network: Microsoft Virtual Private Networking Adapter
Network: Dial-Up Adapter #2 (VPN Support)
Network: AOL Adapter
Operation SystemWindows Millenium Edition
OS Version: 4.90 Build3000
ProductID: 52782-005-1726023-14953
LanguageID: $0409
StandardName: Central Standard Time
SystemUpTime: 15 ·ÖÖÓ, 26 Ãë.
DVDRegion: 1
Internet Explorer: 5.50.4134.0100
Microsoft DirectX: 7.0 (4.07.01.3000)
OpenGL: 4.00
Microsoft Data Access Object: 3.6
Microsoft ActiveX Data Object: 2.5
Borland Database Engine:
ODBC: 3.520.4403.2
Windows ASPI32: 1, 0, 0, 0
------CPU Info------
CPU Info
BrandString: @ @ @
Real Frequency: 133MHz
Code Name: Covington (0.25¦Ìm)
CPU Type: OEM
Vendor: GenuineIntel
Voltage: 3.3V
Transistor Count: 1900ten thousand
External Clock: 66MHz
Multiplier: 2.0
FBS: 66MHz
Memory Wide: 528.0MB/s
Slot: Solt1
Package: SEPP
SerialNumber: 0000-0650-0183-FBFF-0000-0000
CPU ID: 6-5-0
Brand ID: 0
Cache Info
Level1: 32KB
Level1 Code: 16KB
Level1 Data: 16KB
Level2: 0KB
Level3: 0KB
Features
MMX: Support
MMX+: Not Support
3DNow: Not Support
3DNow+: Not Support
SSE: Not Support
SSE2: Not Support
TyperThreading: Not Support
IA-64: Not Support
------Mainboard & BIOS------
Mainboard Info
Model: (HOT-661)Intel i440BX
Manufacturer: Shuttle Inc.
Version: 2A69KH2B
System
Slot
16 bit ISA Slot (Unknown)ID=:0
32 bit PCI Slot (InUse)ID=:72
32 bit PCI Slot (InUse)ID=:80
32 bit PCI Slot (Available)ID=:88
32 bit PCI Slot (Available)ID=:96
Port
PRIMARY IDE: PortSlot_0
SECONDARY IDE: PortSlot_1
FDD: PortSlot_2
COM1: PortSlot_3
COM2: PortSlot_4
LPT1: PortSlot_5
Keyboard: PortSlot_6
PS/2 Mouse: Detected
USB: PortSlot_8
Devices:
BIOS Info
Name: Award Modular BIOS v4.51PGM
ExtendedInfo: 07/07/1999-i440BX-ITE867-2A69KH2BC-00
Copyright: Copyright (C) 1984-99, Award Software, Inc.
BIOS Vendor: Award Software International, Inc.
BIOS Date: 07/07/99
BIOS Size: 256KB
SMBISO Version: 2.0
------Memory Info------
Physical Memory Info
Total: 223MB
Used: 121MB
Left: 101MB
Usage: 54%
PageFile
Total: 574MB
Used: 69MB
Left: 504MB
Useage: 12%
Virtual Memory
Total: 2044MB
Used: 53MB
Left: 1990MB
Usage: 2%
System Resources
System: 77% Left
GDI: 91% Left
User: 77% Left
Memory Address From: 7FFFFFFF
Memory Address To: 00400000
Memory Bank Info
Slot: 1-Way / 1-Way
Speed: 70ns,60ns
Type: EDO,SDRAM
Voltages: 3.3V
MaxSize: 128MB
MemCtrlSlotCount: 4
1Slot:32 MB 60 ns DIMM1
2Slot:32 MB 60 ns DIMM2
3Slot:128 MB 60 ns DIMM3
4Slot:32 MB 60 ns DIMM4
------Disk Info------
Logic Disk
VolumeLabelC)
FileSystem£ºFAT32
SerialNumber£º1529-3638
Capacity£º9709MB
FreeSpace£º494MB
TotalClusters£º65526
SectorsPerCluster£º64
------Display System------
Video Device Info
Adapter: Trident Blade 3D PCI/AGP NO_ICD
Chipset: Blade 3D
Memory Size: 4MB
Type: DDR/SDRam
RAMDAC: Trident-Built-In
Manufacturer: Trident Microsystems
BIOS Info:
BIOS Date:
BIOS Version:
Driver Version:
Driver Date: 08/01/2000
Driver Provider: Trident Microsystems
Monitor
Product Name:
Current Resolution: 1024X768
ColorDepth: 32Bit
Vertical Refresh Rate: 0HMz
Max Resolution: 1024 x 768 - 32 bit
Horizonta lSize: 270mm
Vertical Size: 203mm
Visual Area:13.6inch
------Mutimedia------
Multimedia Drivers
Sound Blaster AudioPCI Legacy Device
Creative Gameport Joystick
Wave-In
Wave-Out
SB AudioPCI Playback v4.4
Mid-In
SB AudioPCI MIDI In v4.4
Mid-Out
SB AudioPCI MIDI Synth v4.4
SB AudioPCI MIDI Out v4.4
Mixer
SB AudioPCI Mixer v4.4
Engine
OpenGL: 4.00
Direct3D
Microsoft Direct3D Mono(Ramp) Software Emulation
Microsoft Direct3D RGB Software Emulation
Microsoft Direct3D Hardware acceleration through Direct3D HAL
DirectMusic
Microsoft Software Synthesizer
DirectPlay
WinSock IPX Connection For DirectPlay
Modem Connection For DirectPlay
WinSock TCP Connection For DirectPlay
------Network------
Network Info
VirtualAdapters
AOL Dial-Up Adapter
Dial-Up Adapter
AOL Adapter
Clients
Client for Microsoft Networks
Services
Protocols
TCP/IP
IPX/SPX-compatible Protocol
NetBEUI
NDISWAN
IP Addresses: 127.0.0.1
TCPIP
AdapterCount: 4
HostName: VALENCIA
DNS Address:
WinSock
Description: Microsoft wsock32.dll, ver2.2, 32bit of Jun 7 2000, at 21:34:15.
Version: 2.2
Status: On Win95.
I would like to get $125 shipped/paypaled for all of this. $80 shipped for all the PC stuff minus the Monitor. I would also part any of it out if anyone is interested. Just PM me.
Computer System
OEM Info:
Hardware Info
CPU: @ @ @
LanguageID: $0409
DVDRegion: 1
OpenGL: 4.00
ODBC: 3.520.4403.2
CPU Info
BrandString: @ @ @
CPU Type: OEM
Voltage: 3.3V
Multiplier: 2.0
FBS: 66MHz
Slot: Solt1
Package: SEPP
CPU ID: 6-5-0
Brand ID: 0
Cache Info
Level1: 32KB
Level1 Code: 16KB
Level1 Data: 16KB
Level2: 0KB
Level3: 0KB
Features
MMX: Support
MMX+: Not Support
3DNow: Not Support
3DNow+: Not Support
SSE: Not Support
SSE2: Not Support
IA-64: Not Support
Mainboard Info
Version: 2A69KH2B
System
Slot
Port
FDD: PortSlot_2
COM1: PortSlot_3
COM2: PortSlot_4
LPT1: PortSlot_5
USB: PortSlot_8
Devices:
BIOS Info
BIOS Date: 07/07/99
BIOS Size: 256KB
SMBISO Version: 2.0
Total: 223MB
Used: 121MB
Left: 101MB
Usage: 54%
PageFile
Total: 574MB
Used: 69MB
Left: 504MB
Useage: 12%
Virtual Memory
Total: 2044MB
Used: 53MB
Left: 1990MB
Usage: 2%
System Resources
System: 77% Left
GDI: 91% Left
User: 77% Left
Memory Bank Info
Slot: 1-Way / 1-Way
Speed: 70ns,60ns
Type: EDO,SDRAM
Voltages: 3.3V
MaxSize: 128MB
MemCtrlSlotCount: 4
Logic Disk
VolumeLabelC)
FileSystem£ºFAT32
Capacity£º9709MB
FreeSpace£º494MB
Video Device Info
Chipset: Blade 3D
Memory Size: 4MB
Type: DDR/SDRam
BIOS Info:
BIOS Date:
BIOS Version:
Driver Version:
Monitor
Product Name:
ColorDepth: 32Bit
Multimedia Drivers
Wave-In
Wave-Out
Mid-In
Mid-Out
Mixer
Engine
OpenGL: 4.00
Direct3D
DirectMusic
DirectPlay
------Network------
Network Info
VirtualAdapters
AOL Dial-Up Adapter
Dial-Up Adapter
AOL Adapter
Clients
Services
Protocols
TCP/IP
NetBEUI
NDISWAN
TCPIP
AdapterCount: 4
HostName: VALENCIA
DNS Address:
WinSock
Version: 2.2
Status: On Win95.
That's what I'm thinking, but with the shipping for it's size and weight it will be more. Make offers though and I'll see about getting the cheapest shipping I can get. I'd take $50 for it if I knew it would ship for a little more than that. Probably better off just parting each piece though.
