asa cam bowhite heads dyno results what do you think
got my combo dyno today ran short on time, but overall after some issues from a falling fuel pump i gained 30rwhp from my mail order tune new era performance tuned the car it made 360rwhp locked on a dyno jet 30% humitdity 75 degrees out heres the specs
-99 ls1 stock bottom end
-gm asa cam 226-236-525 110lsa
-wiend intake,ported maf, ported tb
-custom longtubes 1 /3/4" 3" truse duals into thrush mufflers
-milled bo white 5.3 heads ported 2.02 valve flow is supposed to be likea stock ls6 head from what ive seen
-4l60e shift kit 3500 9.5" redneck performace stall
i have a 100shot but somthign was wrong clogged line or selonoid. the car ran a 12.3 @110 1.8 60ft before the tune so i should gain in the 1/4
what do you think i now its not the best cam but for $100 it fit my budget at the time. tuner said my intake,heads and cam basically suck peek hp was at about 5600rpm shifts set at 6200rpm before at 6400 car weighs 3500 with me in it and 1/2 tank
