99 LS1 into a 94 LT1 car
The 4l60E shares the same internals, but will not bolt up since it has a different bolt pattern..
Ls1 uses a different one, while the LT1 is SBC style( Hence the reason you can boltup TH400s or TH350s)
But with a LS1 you need a plate made to do it
What I did (and what I highly recomend) was get a Helms manual for both the year of your car and the donnor engine/trans. While not absolutely necessary they will helm you a lot and save a lot of questions.
Recomend you just get a LS1 A4 as it's easier.
Re'
Re'
