base tune for a 6.0L l92/L76
Old 05-13-2008, 12:48 PM
69LT1Bird's Avatar
Default base tune for a 6.0L l92/L76
I was wondering if anyone has seen a tune for the above combo. I looked through the repository but I did not see any. I have the car fired but would like something a bit closer for a tune to start me out with.
LQ4
L92 heads
L76 intake
Holley 90mm
Long tubes
39# svo injectors
58 psi at the rail
222_238 581 605 114 lsa+4
10.8:1 compression ratio
any help would be appreciated
Old 05-14-2008, 09:01 AM
69LT1Bird's Avatar
I have tried several things and so far I am not getting any good results. In SD, the AFR is about 13:1 and runs ok but not great. When I turnoff SD and reconnect the MAF, it runs very lean, 17-18:1. I have a NTK AFX wideband hooked up to get the AFR readings, the laptop shows the higher AFR through the EGR setup.
IAC is very high (150-180), when I go into VCM Controls and try to drive down, it shuts the car off. I started with a 2003 Corvette stock tune for my base.
Any help would be appreciated
Old 05-17-2008, 09:05 PM
69LT1Bird's Avatar
I did some further tweaking and took it for a short drive. Attached is the log and the tune files, could someone take a look and give me some feedback.
File Type: hpt
File Type: hpl
Old 05-18-2008, 08:10 PM
69LT1Bird's Avatar
updated tune and log file
