OK I need to find a dyno near Florence SC
My timing is crazy and I cant fix it. I HAVE to drive my car so I cant park it. At WOT my timing is usually 29-30 but once I only got 24 (Is that normal?) I would say it spikes while cruising but there is a steady 39-42 degrees while cruising on a 20 minute drive that was logged three times at part throttle at different RPMs. All else through the log seemed normal showing from 16-34 degrees.
No KR only a glips of .8-1.5 twice on the run and that happened when changing gears. I even went back to my stock tables and the same, no KR but the timing would at some points show steady in the 35-40 degree range.
There is no pinging from the engine.
