New 12 bolt. Low trac and abs inob is on. Please Help!
Old 05-16-2008, 01:59 PM
2001AntiVenom's Avatar
Default New 12 bolt. Low trac and abs inob is on. Please Help!
Alright i put a 12 bolt in my car the other night it is a moser with a 4.30 gear. and my abs inop is on and low track comes on when i hit the brakes. Please help!
Old 05-16-2008, 02:19 PM
Kleeborp the Moderator™
MeentSS02's Avatar
3 channel or 4 channel rear? I'm assuming 4 channel since you are getting the Low Trac light...
Something is messed up somewhere...you need to make sure the sensors are close enough to the reluctor wheels, and you need to also make sure the wiring is okay. Good luck...that is exactly why I ordered my Strange without ABS/TCS.
Old 05-16-2008, 04:58 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Yea, make sure the abs reluctor wheel are at the end of the axles and are acutally there. As well as the 2 sensors. Also if you had taken the brakes off, re bleed the system.
Reset the PCM as well just to clear everything out.
